4/15/2022 2:51 PM | |
Joined: 9/27/2006 Last visit: 11/18/2024 Posts: 12296 Rating: (2691) |
Hello Vishakha; When you are working with Siplus modules, you have to understand that these are basically standard modules, modified to resist higher temperaure ranges, corrosive environments, high altitudes... Look at the screenshot below, you will find a description of your 6AG1155-6AU01-2CN0 CPU and find that it is actulally a modified 6ES7155-6AU01-0CN0. You have 2 choices: you could simply enter the part number that the Siplus equipment is based upon (6ES7...) in your hardware configuration, or you can follow the suggestions in the following document; - How do you configure a SIPLUS extreme component with the TIA Portal? https://support.industry.siemens.com/cs/ww/en/view/109746275 Hope this helps, Daniel Chartier |
4/15/2022 3:12 PM | |
Joined: 2/8/2018 Last visit: 3/28/2023 Posts: 256 Rating: (4) |
Well thanks for reply , first option can be tried but the second link that you have shared i have already seen it and not getting any help from that . |
