11/24/2015 3:27 PM | |
Joined: 3/9/2015 Last visit: 4/18/2024 Posts: 34 Rating:
I exported my FC to an xml file then i deleted it in tia portal but when i try to import the xml file I always get this error i uploaded my fc i want to import AttachmentConv 2.txt (365 Downloads) |
11/24/2015 4:07 PM | |
yes but i'm using the Openness demo (https://support.industry.siemens.com/cs/document/108716692/tia-portal-openness-introduction-and-demo-application?dti=0&lc=en-WW ) to import /export functions witten in Lad to xml. exporting works great but when i import i get that error |
11/24/2015 5:45 PM | |
Joined: 7/7/2010 Last visit: 7/25/2024 Posts: 15000 Rating:
You may want to create a support request "mySupport" in the forums and ask this one. LAD cannot be imported using TIA Portal for the s7-1200's for sure.
science guy |
7/12/2016 10:54 AM | |
Joined: 7/8/2016 Last visit: 7/9/2024 Posts: 1 Rating:
You need "Enabler File" and "Usage File".Attachmenttia_portal_openness_guidance_usagefile_enablerfile_v13sp1.pdf (474 Downloads) |
10/11/2016 12:39 PM | |
Posts: 1 Rating:
Hey. Did you solve your problem? Because i have the same problem. Although i have already the usagefile and enablefile. Thank you for answering. |
