11/9/2016 3:12 PM | |
Posts: 52 Rating:
I'm importing tags from simatic to WinCC. I have 1. SImatic Manager v55 2. WinCC 7.3 The process 1. I have in simatic manager one OS that I compile to transfer the tags from SIMATIC to WinCC 2. I imported one stl source to import one DB in my project. 3. When i make a compile on this source the tags from the data block appear in tag management , but in tag management in row address i see this : DB942,DB0+142. I don't see the bit i want to tag into my graphics (DB942,db142.0) *Problem 1: example, i have two valves and i want to give them the addresses. DB in Simatic all have bits and i'm trying to give each valve his bit address but i can't because i see for each tag name the same address (DB942,DB0+142). Now I don't know how to make the bit address visible in tag management. I don't know what causes this transformation and how i could make all tags visible in WinnCC. problem 2. When i try to compile all from OS in SImatic, in data type i dont see anymore type: Binary tag just ByteToUnsignedByte. What is the cause of this problem i don't know.
AttachmentTAG.zip (73 Downloads) |
