7/10/2018 8:18 AM | |
Joined: 7/9/2015 Last visit: 8/6/2024 Posts: 3913 Rating: (577)
Hi, please check the following entry. This entry includes instructions for assigning parameters in the PG/PC interface and describes the remedy if the device driver cannot be selected or is not visible. How do you generally parameterize the PG/PC interface and how do you ensure that the device driver can be selected and is visible?Regards, Towome |
8/25/2018 3:34 PM | |
Joined: 1/17/2018 Last visit: 8/2/2024 Posts: 24 Rating: (2) |
Confirmed working solution! Thank you very much |
8/16/2019 6:53 AM | |
Posts: 1 Rating: (0) |
Hi vikram same issue i have and i tried you says but not help. Please suggest if any solution |
8/16/2019 7:12 AM | |
Joined: 5/12/2006 Last visit: 8/5/2024 Posts: 22334 Rating: (3000) |
hello, you must run the cmd shell as admin (Run as administrator) Regards Christoph |
4/4/2020 1:13 AM | |
please , shall i get more info about how can i follow your instructions? thank you |
