5/8/2018 1:49 PM | |
Posts: 107 Rating:
Good day all. Could someone explain please what is the difference between PLS SIM and real CPU 315-2DP For example : L DB2000.DBW2 // FROM HMI ITD L 1.000000e+003 * R T MD 50 CALL FC 40 //time to S5 timer IN :=MD 50 RET_VAL := DB1.DBW70 // TO PLC PROGRAMM in simulator works fine BUT in the real CPU not transferring to MD50 (also tried other Merkers and DBs result the same) ??? don't understand why. MD not used anywhere except here. Thanks in advance. IT_Service ------------------------------------------------------------------------------------------ |
Last edited by: IT service at: 5/8/2018 1:50:19 PMLast edited by: IT service at: 5/8/2018 1:50:51 PMLast edited by: Jen_Moderator at: 5/9/2018 8:51:28 AMNew subject after splitting |
5/10/2018 7:07 AM | |
Posts: 107 Rating:
Ok.. thank you.. any way I dont need floating in the end so I will try to multiply D. IT_Service. |
5/11/2018 6:40 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
New question published by IT service is split to a separate thread with the subject Insert receipt (numbers) from office PC to PCS7 in-out fields. Best regards |
