6/19/2017 8:07 AM | |
Joined: 12/9/2010 Last visit: 10/8/2022 Posts: 623 Rating: (76) |
Hi Dynasty190, Check hardware configuration. Ur hardware cfg and actual connections to F-modules should match. |
If you like the comment, rate it (right top) or thank it (left bottom). |
11/18/2021 4:39 PM | |
Joined: 10/30/2020 Last visit: 10/3/2023 Posts: 4 Rating: (0) |
You must use the input in your program, |
11/23/2021 11:32 AM | |
Joined: 3/11/2019 Last visit: 6/27/2024 Posts: 1487 Rating: (268) |
Hi, there is also an FAQ for that topic, maybe this helps make things clearer Why does the status of fail-safe inputs and outputs not change in the watch (monitoring) table?regards sancruz |
Feedback appreciated, please rate |
