5/19/2020 6:52 AM | |
Posts: 5 Rating:
Hello Experts Is is possible that I install the braking resistor ( 6SL3000-1BE32-5AA0 ) with the side down? I wanted to put the braking resistor on the panel. Can anyone give solutions? I have uploaded the 3-D drawings about the resistor. Thanks
Attachment6SL3000-1BE32-5AA0_3D_en.pdf (177 Downloads) |
5/19/2020 6:54 AM | |
Posts: 5 Rating:
This is the picture of the resistor. |
5/19/2020 2:16 PM | |
Joined: 10/11/2006 Last visit: 8/7/2024 Posts: 5887 Rating:
Hello, Please check out chapter 6.2.4 of the G130 component manual, where you can find important points for installation of the braking resistor. https://support.industry.siemens.com/cs/ww/en/view/109765022 |
With best regards, |
5/20/2020 6:31 AM | |
Posts: 5 Rating:
Thank you for important information. Unfortunately, there's no enough place to mount the resistor vertically. (There's only low and wide place) Can you explain what problem will happen, if we mount the resistor horizontally? I could find the points about install issues from manual, but I couldn't find the clear reason why the resistor must be mounted vertically. I would be really grateful if you could explain the reason. (Actually, I need to explain the reason why the resistor must be installed vertically) Thanks
Last edited by: AutoGen_6559435 at: 05/20/2020 06:51:41Last edited by: AutoGen_6559435 at: 05/20/2020 06:52:17 |
