9/26/2018 8:41 PM | |
Joined: 9/27/2006 Last visit: 9/10/2024 Posts: 12282 Rating: (2683) |
Hello Max; Open the following download page from Siemens Support, it contains a "Batch-File as remedy in case of problems with not correct installed Windows-Update "KB3033929"" for DIGSI v7.50 incl. Hotfix 4. https://support.industry.siemens.com/cs/ao/en/view/109740543 Hope this helps, |
10/10/2018 10:08 AM | |
Posts: 1 Rating: (0) |
Hello, I can not install Digsi 5 Ver. 7.5 on my new Laptop (windows 10 Pro) with the warning in SetupBundle.txt file: ---------------------------------------------------------------------------------------------------------------------------------- Not able to open the key SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\A340B3C62E6582F4683F819D77E44A89\InstallProperties ---------------------------------------------------------------------------------------------------------------------------------- I read in manual, the setup fail in Prerequisites will be solved after enaable the windows update service. I turn on it but setup also fail. Kindly help me in this case. Best regards, Nguyen Nghi AttachmentDIGSI_V7.50_SetupBundle.txt (855 Downloads) |
12/8/2019 3:54 PM | |
Hello. You must download and install the correspondent file. Batch-File as remedy in case of problems with not correct installed Windows-Update "KB3033929" https://support.industry.siemens.com/cs/ww/en/view/109758531 Best regards, Marco Vernaglia |
Last edited by: AutoGen_7448758 at: 12/08/2019 15:57:10Last edited by: The Helping Hand at: 12/09/2019 15:08:58Last edited by: The Helping Hand at: 12/09/2019 15:09:14Optimized Link |
4/15/2020 4:15 PM | |
Posts: 2 Rating: (0) |
Hello, Have you fix it ? Best regards |
