4/6/2023 8:31 AM | |
Joined: 1/21/2013 Last visit: 7/5/2024 Posts: 2957 Rating:
Hi Adarsh RS, Yes, you can install your own software on the ET 200SP Open Controller, CPU 1515SP PC2. However, you should be aware of the operating system, as Windows 10 IoT is slightly different from "normal" Windows 10 and therefore your software may not support Windows 10 IoT. And you should be aware of the low performance as it is only equipped with an Intel Atom E3940. Kind regards |
