10/16/2010 7:51 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating:
Hello Rahul, Look at http://support.automation.siemens.com/WW/view/en/1175533 Best regards, Hristo Mihalev |
10/16/2010 1:20 PM | |
Joined: 10/7/2005 Last visit: 6/21/2024 Posts: 3008 Rating:
Hello Rahul Sayre there is no such thing as a "one size fits all" S5 instruction list as S5 CPU's differed considerably from each other concerning the available/useable instruction set, type of inbuilt "system" FB's and OB'1, memory usage etc. I suggest you go to https://support.automation.siemens.comand do a search for the specific S5 CPU/System that you are using/interested in and download its manual (which contains a list of the instructions).An example link for the928B (3UB21 version) is HERE. If you search foroperations lists you'll alsofind "pocket type" style pdf's likeTHESE which are handy to have as a quick reference guide when working with S5's. I hope this helps |
Cheers |
