6/20/2017 5:07 PM | |
Joined: 4/28/2015 Last visit: 5/15/2024 Posts: 3345 Rating: (377)
Hi, where did you find this image with apache? Is this an image based on the Poky Linux for the IOT2000? You can find a list of the most common Linux commands for example here or here. Usually the version is display with
I think you can find the handling of the apache if you search for it in google. Unfortunately I can't test the command at the moment. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
6/22/2017 3:49 PM | |
Posts: 29 Rating: (0) |
Ok, found it! Just a connection via SFTP with FileZilla. Regards |
