3/13/2020 7:23 AM | |
Posts: 12 Rating:
Hello, I tried with a new image and a new SD card, but the IOT2000 is still not responding. Best regards, Clemens ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/13/2020 08:04:30New subject after splitting |
4/8/2020 2:52 PM | |
Posts: 2 Rating:
Hi, I’m also dealing with the same problem
4/24/2020 2:28 PM | |
Posts: 12 Rating:
Does the IOT2000 Serie have any kind of BIOS, that may have been damaged?
4/24/2020 3:26 PM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating:
Hi, did you try another SD card already? There is a way to get connected via serial connection. Therefore you need a TTL cable. For example this one Using putty via this connection you can see if the image has booted or not. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
4/27/2020 12:45 PM | |
Hi, do you have a SIMATIC IOT2040 (6ES7647-0AA00-1YA2) or a MindConnect IoT2040 (9AC2112-0AA00-1YA2)? That's the last thing I can think of. Or do you have a TTL cable, something like this? Best regards! |
