1/16/2018 10:23 AM | |
Posts: 531 Rating:
Did you check the ports used and whether broadcast can be send between IOT and OPC Server? |
1/17/2018 11:52 AM | |
Posts: 80 Rating:
I am not sure if the captures are clear... -UAExpert: connection done -UAExpert2: beginning trying to connect to a disconnected server and then connection done -Kepware: connection failed Thanks!!! AttachmentWireshark captures.zip (236 Downloads) |
1/17/2018 12:37 PM | |
Posts: 80 Rating:
From Kepware, I can see the server but it says that there is "No UA Endpoint" |
