2/28/2022 7:28 AM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating:
Hi, you need to install the node in version 2.1.1 via terminal
More info see here. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
2/28/2022 7:48 AM | |
Joined: 8/20/2021 Last visit: 2/9/2023 Posts: 19 Rating:
Thanks for your message, the node (version 2.1.1) is running correctly , but it does not support DTL , is there other solution?
2/28/2022 11:42 AM | |
Hi, I once created a flow, reading the date and time byte by byte and convert it afterwards. Maybe it helps. Best regards! |
3/2/2022 8:49 AM | |
That is really useful, thanks a lot! Otherwise, do you know how to use redis in iot2040? I have installed node-red-contrib-redis, but i do not know how to run the redis-server, does it need i install another software? In PC, i got a redis-server.exe and run it, then i can use the node of redis normally.
3/2/2022 12:42 PM | |
Hi, this node only seems to be a redis client not a server. I am not sure whether it is easily possible to install a redis server on the IOT2040, as there is no possibility to add software via e.g. apt. The only way to add software to the IOT2040 is either compiling the software from source on the IOT2040 or build a custom image with the software included. I found this website describing the installation from source: https://redis.io/topics/quickstart Best regards! |
