9/15/2020 1:37 PM | |
Joined: 6/7/2019 Last visit: 11/11/2021 Posts: 10 Rating:
Hi, I use Node OPC_UA Server (palette:node-red-contrib-opcua 0.2.32) in node-red on IOT2040. So the OPC ua go in crash after about 3 hours . It s seems the OPCUA SERVER node is very instable. you have suggestions for solving the issue. In attachment the flow I am using. Best regards Marco Attachmenttest flow.txt (443 Downloads) |
9/17/2020 7:37 PM | |
Joined: 12/12/2016 Last visit: 4/8/2024 Posts: 640 Rating:
Hello, Yes we have tested this before and the node crashes after a few hours... due to some unidentified Bugs in the v8 runtime which powers NodeJS. I would check its working stable with native nodejs like in one of our examples. (might be a little outdated) Or compile a server using a different OpenSource library like Open62541 BR |
