11/3/2017 9:14 PM | |
Joined: 12/9/2014 Last visit: 2/21/2022 Posts: 4 Rating: (0) |
Hi Is it possible to change some logic from OB35 to OB37? I already have some CFC running in both OBs Thanks Didn't think that was just drag and drop, done, sorry ------------------------------------------------------------------------------------------ |
Last edited by: Caio at: 11/3/2017 9:33:01 PMLast edited by: Jen_Moderator at: 11/6/2017 12:44:03 PMNew subject after splitting |
11/9/2017 2:02 PM | |
Joined: 9/9/2015 Last visit: 10/10/2024 Posts: 728 Rating: (279) |
Yes, definitely. The consequences- This will cause the CPU loading to increase. The best performance should be running your program with 2 or 3 OB enough, not in too high scan time. And if u set to OB37, with the default OB time, every OB35 scan cycles will have a lot of rounds of OB37 scan. The time taken to complete OB35 program will be increased. Furthermore, if you need to read data from your field devices, what is the whole loop response time? You process the same data few rounds. Hope this helps. |
Please give me 5 stars Rating if my post is helpful for you. :) |
