5/2/2011 9:54 PM | |
Posts: 13 Rating: (0) |
Dear all, One more thing please, is it possible to use a ramp with multiplexer ? I have a motor running at four diferent speed depending on the switch being activated. I would like put a ramp to just one of them. Meaning when the user activates F4 program, the motor either spins at much slower ramp for initial period (cca. 10 minutes) then gets to the value selected by the multiplexer (900). But I do not want the ramp on the other three programs. If it is not possible is it possible to put another pulse relay sort of for the initial period where the pause is much longer => so the two relays operate in a timing sequence. Once again thank you very much for your help. Application is atached. Yours Sincerely Karel Splitted from Pause a program, two pulse signals consecutively. AttachmentSaw Dust Drum.zip (280 Downloads) |
