5/30/2020 9:10 PM | |
Joined: 8/13/2016 Last visit: 4/21/2024 Posts: 55 Rating: (2) |
Just to raise this from the dead - Is it possible to do what is asked below in WinCC Advanced v16? That is not a lot of points for a database...
Last edited by: Jen_Moderator at: 06/02/2020 09:38:17New subject after splitting |
6/4/2020 12:39 PM | |
Joined: 8/3/2009 Last visit: 5/27/2024 Posts: 12984 Rating: (1653)
Hello LostinFog In the Archive System 500000 Entries per Log is the maximum. you can try to use a workaround like this: https://support.industry.siemens.com/cs/de/en/view/109477071 Bye Murof |
