8/17/2017 1:36 PM | |
Posts: 29 Rating: (1) |
Do you know a way to make your application comunicate with the NCU and the PLC without having Sinumerik Operate running on the PC or at least puting it on the background. Sinumerik Operate always have a bar on top of everything. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 8/18/2017 12:15:51 PMNew subject after splitting |
9/14/2017 10:33 AM | |
Joined: 9/14/2017 Last visit: 3/8/2022 Posts: 7 Rating: (0) |
For newer Sinumerik 840D SL 828D controllers with software Operate 4.5 or 4.7 you could use OPC UA if option Access MyMachine /OPC UA 6FC5800-0AP67-0YB0 is available and activated. Test programs as well as detailed instructions can be found here: 4.5:https://www.inventcom.net/support/siemens/sinumerik-840d-828d-opc-ua-sw-45 4.7:https://www.inventcom.net/support/siemens/sinumerik-840d-828d-opc-ua-sw-47 Instructions on setup of OPC UA with free Sinutrain versions are also included! AttachmentSinumerik_840D_SL_Operate_OPC_UA_4_5.pdf (287 Downloads) |
