6/30/2010 3:57 PM | |
Joined: 2/10/2006 Last visit: 3/21/2024 Posts: 147 Rating: (12) |
If you really would like to do testing of your complete program by changing I/O's you should consider using 505 simulator from Fastrak. See attached pdf file. This software will allow you to build scenario's for the state of your I/O and variables, save them and repeat them as many times as you want. Very usefull for FAT, testing large sequences, projects subject to FDA validation etc.. Other advantage: your simulation is separated from your PLC program. No need to modify your program when you're done simulating and want to loadthe programin the real PLC. Attachmentsim505[1].pdf (783 Downloads) |
7/6/2010 1:38 AM | |
Posts: 99 Rating: (3) |
Thanks Daniel That does the job well Good memory! |
