5/26/2010 7:24 PM | |
Posts: 4 Rating:
Is there some help on Interfacing single channel Siwarex U modules to a Wonderware Intouch HMI through the Step 7 interface? Splitted from Siwarex U end-user interface help. |
6/2/2010 5:20 PM | |
Joined: 9/27/2006 Last visit: 7/16/2024 Posts: 12268 Rating:
Hello vossman; Once you have collected the Siwarex U data in your S7 PLC, use Wonderware DASSIDIRECT (OPC) driver to exchange data with InTouch. Have a look at the following setup manual: http://www.cmontmorency.qc.ca/~jboissar/SIEMENS/Doc_siemens/DasSIDirect.pdf Hope this helps, Daniel Chartier |
