11/12/2009 6:35 PM | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Joined: 4/19/2008 Last visit: 6/25/2024 Posts: 1525 Rating:
Hi electricalgg, Please follow the compatibility list below when using Windows operating systems and SIMATIC ProTool/Lite, SIMATIC ProTool and SIMATIC ProTool/Pro:
1.) Windows 95 OSR 2 (Build 950b) or higher http://support.automation.siemens.com/WW/view/en/23160061 Also you can find the same information at following link.As per table Protool Pro V5.0 is not work with Windows XP Pro, Please installed Protool Pro V6.0 SP3, as I suggest you, because I insatlled Protool Pro V6.0 SP3 on WinXP Pro. SP2it works fine, but not try with WinXP Pro. XP3. |
11/12/2009 7:01 PM | |
Posts: 12 Rating:
Thank you Ammy |
