11/2/2023 8:44 AM | |
Joined: 6/27/2017 Last visit: 6/26/2024 Posts: 158 Rating:
What do we need to solve your problem? |
11/7/2023 2:33 PM | |
Joined: 8/3/2009 Last visit: 7/30/2024 Posts: 13393 Rating:
Hello TPitchure you use Javascript so I suppose you use WinCC Unified https://support.industry.siemens.com/cs/ww/en/view/109813308/155460399115 As you can see it creates only an Object in your Javascript context. So you can use the HMI tags you are using in a Tagset also individdual in different contexts like IO fields or other scripts. How to use the tagset you see in the help system. Bye Murof |
