1/29/2016 6:10 PM | |
Joined: 6/5/2014 Last visit: 7/21/2024 Posts: 109 Rating: (2) |
can i know all the chnages made in the PLC Program for S7-400 and S7-300 and when these changes made ? |
1/29/2016 6:43 PM | |
Joined: 9/27/2006 Last visit: 10/13/2024 Posts: 12287 Rating: (2685) |
Hello Hanzalh; You must have some add-ons to your programming software in order to do this type of change management. The combination of software described below will limit the access to your PLC programs to authorized personnel, log all changes (by creating new versions of the program archives) and allow supervision of the changes. Start by looking at fritz’ post in this thread: Step 7 change management https://support.industry.siemens.com/tf/ww/en/posts/41544/ You can look at a demo of the software management system here: Webcast: Visioning and Comparison of Projects with SIMATIC Version Trail and SIMATIC Version Cross Manager (go down to bulletpoint #8)
Here you can find Siemens Industry Mall (electronic catalog) entries for the latest version of;
https://mall.industry.siemens.com/mall/en/ww/catalog/products/10045928?activeTab=order®ionUrl=WW
https://mall.industry.siemens.com/mall/en/WW/Catalog/Products/10045927?tree=CatalogTree
https://mall.industry.siemens.com/mall/en/ww/Catalog/Search/?searchTerm=simatic%20logon&tab=Product Hope this helps, Daniel Chartier |
1/29/2016 9:21 PM | |
hi Daniel Chartier, i face problem, the system tells me i am not register in the system when i open the first link |
1/29/2016 10:52 PM | |
Hello Hanzalh; I corrected the first link, to point to a thread in this forum. Sorry for the mistake on my part. Do you have trouble accessing the links that start with mall.industry.siemens... You do not have to be logged in to access the data; this is only for companies that have registered with Siemens so they can get pricing and other restricted information. General users can access without login. If access is still a problem, open the Industry Mall link directly in the following link and do a search for the product you need in the Search box there: https://eb.automation.siemens.com/goos/WelcomePage.aspx?regionUrl=/&language=en Hope this helps, Daniel Chartier |
1/29/2016 11:57 PM | |
Hello Mahmoud; No, there is no such database integrated in Simatic Manager, with data available to the user program. As stated before, you need to add some software licenses to log changes in the Step 7 programs. What is available in Simatic Manager is a manual Compare Online/Offline function, through which you can compare code on the CPU and a saved file on your PC. So if you have a master copy of the last saved version of the PLC program, you can compare it with the existing blocks on the PLC and validate that it has (or has not ) changed since the last save. The first operation of the compare function checks whether timestamps for the different blocks have changed; if they have, open the blocks (ion the same screen) to see where changes have been implenmented in your code. See bthe attached screenshot, taken for the following ,manual: SIMATIC Programming with STEP 7 V5.5 https://support.industry.siemens.com/cs/ww/en/view/45531107
But if you want this type of functionality automated in your project, you must purchase and install the suggested software licenses. Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 1/30/2016 12:54:33 AMLast edited by: dchartier at: 1/30/2016 3:42:49 AM |
2/20/2016 4:07 PM | |
Hi Jack, Can yo tell me the name of this program Best regards, Mahmoud Hazem |
