10/28/2020 2:02 PM | |
Joined: 9/21/2017 Last visit: 11/3/2021 Posts: 30 Rating:
KP 1200, have the same problem Works only if it connect directly to PC, via router always failed ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/29/2020 06:59:25New subject after splitting |
10/30/2020 3:08 PM | |
Joined: 8/3/2009 Last visit: 8/15/2024 Posts: 13561 Rating:
Hello DO you have unlock the Ports for HMI Transfer and loading in the Routers Firewall? Do you have set the router´s IP Adress in the IP Config of the Panel ? Check this FAQ: https://support.industry.siemens.com/cs/ww/en/view/109781206 Bye Murof |
