7/15/2019 9:13 PM | |
Joined: 9/27/2006 Last visit: 4/28/2024 Posts: 12257 Rating: (2665)
Hello Logic_Lover; Here you will find information (from the Siemens Industry Mall) on the KTP300 operator panel. The included information includes the phrase "configurable from WinCC Basic V11/ STEP 7 Basic V11". https://mall.industry.siemens.com/mall/en/WW/Catalog/Product/6AV6647-0AH11-3AX0 If you do have TIA Portal v11 (or a compatible version) in hand to program the KTP300 you will need to use the "device proxy PLC" technique, allowing a PLC programmed in Step 7 v5.x, to talk with the KTP300. See this Application example for more details; Combined configuration with WinCC (TIA Portal) and STEP 7 V5.x (Video) https://support.industry.siemens.com/cs/ww/en/view/73502293 Hope this helps, Daniel Chartier |
