7/6/2023 2:07 PM | |
Joined: 5/6/2022 Last visit: 9/27/2024 Posts: 455 Rating: (90) |
Hi AlesPoljakNOJP, When loading the program, check if you have selected, in the loading dialog box, if it goes via Ethernet or Profinet. I recommend that you try to communicate through Ethenert and that you carry out the typical checks that are discussed in the following FAQ that I share with you, to see if there may be something wrong: Best regards!
