4/11/2017 2:03 PM | |
Joined: 9/15/2015 Last visit: 7/1/2024 Posts: 67 Rating:
FYI |
11/24/2022 12:15 PM | |
Joined: 4/16/2022 Last visit: 6/21/2024 Posts: 24 Rating:
I have the same problem with KTP 1000 basic panel DP. Any news or work around for this problem? |
11/29/2022 11:31 AM | |
Joined: 8/3/2009 Last visit: 7/31/2024 Posts: 13425 Rating:
Hello lonut.S As we have described the only possible way to do a Reset to factory settings for a Basic Panel 1st Gen with DP is to use a PPI MM Cable. The way how and which cable you can use is lised in the basic FAQ: https://support.industry.siemens.com/cs/ww/en/view/19701610 (this is the only way and there is no workaround) Bye Murof |
