4/6/2024 11:07 PM | |
Joined: 12/29/2023 Last visit: 5/15/2024 Posts: 15 Rating:
hello how i can update an HMI KTP400 (6AV2123-2DB03-0AX0) firmware, where i can find this firmware. thank you |
4/7/2024 9:11 AM | |
Joined: 3/30/2020 Last visit: 7/31/2024 Posts: 4665 Rating:
Use the WinCC (TIA Portal) software. See the entry "Updating the operating system using WinCC" in the software help. Or use the Prosave software that is already installed on your PC if you have TIA Portal. The other option is to use a USB drive. That should be documented in the manual. The firmware can be found: |
Activities of this user is voluntary. There is no obligation or liability placed on this user. Though optional, your 'please' and 'thank you' is highly valued. |
4/7/2024 8:56 PM | |
Joined: 9/21/2012 Last visit: 8/1/2024 Posts: 4060 Rating:
If you have TIA Portal installed, use that to update the firmware. |
