11/21/2022 7:44 AM | |
Joined: 4/24/2006 Last visit: 10/18/2024 Posts: 8746 Rating: (1169)
Hello, Have you seen these links: Why can you not transfer the HMI configuration to the panel? Which connector cables are available for connecting to SIMATIC Panels? It could be a problem of used cable. And try to change 'Highest address' to 32 Best regards, Wizard |
11/28/2022 1:40 PM | |
Hello, Try to use an USB stick, see the following link: USB Recovery (Reset to factory) Mode for 2nd Generation Basic Panels Please have in mind: ****************************** Requirements
****************************** Best regards, Wizard |
