5/5/2020 10:21 AM | |
Joined: 2/5/2013 Last visit: 9/5/2024 Posts: 321 Rating: (74) |
Hi Jiri Libich, Below are some suggestion. Option 1 1.Put Alarm Window on separate screen and use button with visiblity on every required screen to navigate separate alarm window screen. Option 2 1.Put Alarm window every required screen on its higher layer with visiblity property. Option 3 1.If possible use Alarm indicator on global screen to navigate Alarm screen.
AmolG. |
Please rate it. |
5/5/2020 10:43 AM | |
Joined: 11/4/2015 Last visit: 7/22/2024 Posts: 31 Rating: (0) |
Thank you AmolG, for sure if there will not be any other option how to do it my way I will need to do it with some way you suggested. But it can be quite painfull if you have many screens (placing hundereds alarm views or navigating buttons) More elegant would be to have only one alarm view at template and use this template at all my screens. And by the way your suggested option 3 is not applicable on my project because I'm not using alarm window but Alarm view. With Alarm indicator I can only show/hide alarm window. Nothing else. Thanks |
5/5/2020 11:02 AM | |
With Option 1 You need just put singal navigatiotion button with color/visiblity property on template screen. There is high priorty considered for layers in normal screen over layers in template screen. Even though you put object on 31 layer on template screen and if you assign template to any screen. Then object kept on 0 layer of normal screen will make obect invisible which is kept on 31st layer of template screen. Br, AmolG. |
