12/14/2022 3:11 PM | |
Joined: 7/19/2022 Last visit: 6/28/2024 Posts: 373 Rating: (61) |
Hi abmarcan, Try transferring the last V17 image to your panel again, with Prosave and the "Factory Reset" option. Then transfer the project again and perform the configuration for the web server in the panel. |
12/22/2023 9:43 PM | |
Joined: 8/13/2018 Last visit: 2/29/2024 Posts: 2 Rating: (0) |
Did you manage to fix this issue, i have the same problem. |
6/26/2024 11:33 AM | |
Joined: 8/3/2009 Last visit: 7/12/2024 Posts: 13284 Rating: (1686)
Hello abmarcan I tested it with Win11 in my site and it works with the SmartServer on a Basic Panel 2nd Gen Which SmartClient Application do you use? Check if its the same as here: https://support.industry.siemens.com/cs/de/en/view/109482434 bye Murof |
