1/2/2024 2:44 PM | |
Joined: 5/6/2022 Last visit: 6/25/2024 Posts: 424 Rating:
Hi Kulanar, Please check that you have performed all necessary steps to recalibrate your panel: "SIMATIC HMI HMI Devices HMI Devices Basic Panels. Touchscreen Calibration" https://support.industry.siemens.com/cs/ww/en/view/31032678/39853821195 Anyway, is the calibration that is wrong is it the screen size or the touchscreen? Does it happen to you only in the project or with any Basic panel function? Have you tried performing a factory reset? I share with you the link where you will find the steps in case you don't know them: "How do you do a SIMATIC HMI operating system update (firmware update, OS update) on operator panels or perform a "Reset to factory settings"?" Best regards! |
