3/18/2009 4:56 AM | |
Joined: 9/27/2006 Last visit: 7/8/2024 Posts: 12268 Rating:
Hello mahmoud; Landis Staefa is a Swiss company that has been marketing HVAC equipment (controllers, motor starters,thermostats,transmitters) for over a 100 years. Recently they have been bought by Siemens. The first thing you must do in order to pursue your search is to identify the model of the controlkler you have and wish to put back into function. There are many different models in the Landis Staefa catalog, as you can see from this simple Google result: http://www.google.ca/search?hl=en&q=Landis+Staefa+manuals&meta= The best place to locateyour documentation easily (depending on how old the system is),is with Siemens Building Technologies; for a first step, look at their their support website. Itcan be found here: [theyshow 924 hits for "Landis&Staefa"] http://www.buildingtechnologies.siemens.com/support/download.htm?languagecode=en If the SBT support pages cannot help you, I recommend you contact their service department directly.Siemens in Egypt should be able to help you also. Hope this helps, Daniel Chartier The NRK16/A controller seems to have been integrated in various lines of products from SBT.Maybe these links can help you look for information on it, if the Landis&Staefa search gives no result: NRK/16A document from SBT-USA NRK16/A in Pronto IRC line. SBT Russia: |
Last edited by: dchartier at: 3/18/2009 7:10 AMNew links to NRK16/A controller information |
