4/1/2011 1:23 AM | |
Posts: 672 Rating: (57) |
Hi, You sure you've got GA3 ? Pee |
4/1/2011 7:14 PM | |
Posts: 5 Rating: (0) |
Definetly a GA3 Not sure on the EPROM numbers yet |
The MD section only goes to 171 |
4/6/2011 8:21 PM | |
Anybody have any input? |
4/7/2011 9:59 AM | |
Hi, Standard 810T GA3 has language change option using machine data 250. You have machine data up to 171. The book I have doesn't have a description for MD171 so it's a bit of a mystery to me. Has the machine come from an eastern bloc country and so might have export software eproms fitted ?. Check you eprom against the attachment. pee Attachment810 sw.pdf (314 Downloads) |
1/2/2013 6:14 PM | |
Posts: 1 Rating: (0) |
sir v have siemens 810t ga3 controlled machine . v lost the edit key .so cannot enter the offset value. is any other idea to input value |
