6/13/2017 8:27 PM | |
Joined: 9/27/2006 Last visit: 6/2/2024 Posts: 12259 Rating: (2670) |
Hello Tekabi; Others have faced a similar problem, with Arabic, on a TP 277, with WinCC Flexible. Since Farsi uses the Arabic alphabet, maybe it could be a solution. See Ayman Elotaifi's second pont on the second page of this discussion. If your programming software is TIA Portal and the proposed solution does not help you, please advise. Hope this helps, |
