9/2/2009 2:51 PM | |
Joined: 4/24/2006 Last visit: 7/12/2024 Posts: 8711 Rating:
Hi, See chapter 5.8 Best regards, Wizard |
Last edited by: Wizard at: 9/3/2009 9:15 AMH-H is right, I think I was still sleeping ;-)) |
9/3/2009 8:06 AM | |
Joined: 7/2/2008 Last visit: 7/2/2024 Posts: 928 Rating:
Hello Wizard, MaybeDrozerce has S7-400 module since it has EXTF LED (S7-300 modules have only SF If it is S7-400 module then chapter 5.17 should be read in SIMATIC S7-400 S7-400 Automation System Module Data. I also do recommend to check the hardware online. I believe it should be either indicated in diagnostic buffer or the module itself should be marked in red with a diagnostic message in hardware configuration online window. Best regards. H-H |
9/7/2009 9:59 AM | |
Hi drozerce, Great, you solved your problem Best regards, Wizard |
