8/23/2012 2:45 PM | |
Posts: 2348 Rating:
Please specify what LED form slave CPU you want to display, which is not available in master? Extf of module or? |
9/23/2012 5:16 PM | |
Posts: 3 Rating:
hi elake , try to explore , solution for ur problem best of luck,
3/1/2015 11:19 PM | |
Joined: 11/29/2011 Last visit: 6/6/2024 Posts: 1358 Rating:
Hi, S7-400H Instruction List CPU 412-5H PN/DP, 414-5H PN/DP, 416-5H PN/DP, 417-5H PN/DP manual under chapter "Sublist of the System Status List (SSL)" states: "0392 Status of the back-up battery of a CPU rack if at least one battery fails So if you set up your SFC51 with these SSL ID it should.... If you have any further question please come and ask! |
Last edited by: MicroMan at: 3/1/2015 11:22:26 PM- What you read here, please check with manuals and your requirements. |
