1/12/2012 2:01 PM | |
Posts: 5 Rating:
sorry i'll explain it better I want a light to go on/off automatically with a timer/ at all times i need to control the light manually. even when the timer has switched the light on or off i need to override it manually i have attached what i made so far Attachmentlogo.zip (235 Downloads) |
1/12/2012 8:06 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Hello, Hope i understand correct what you mean. Try attached program. There is one little bug, if clock has set output, you have to make and brake input1 to switch off the output Maybe you can fix that by yourself, no more bits and bytes for me today Regards, Marcjan Attachmentclock and switch.zip (189 Downloads) |
1/12/2012 8:14 PM | |
Joined: 12/27/2006 Last visit: 7/7/2024 Posts: 1197 Rating:
I have made something, but it works NOT exactly as you wishes. Your wishes are not possible to make! But i think this is what you want. Let me know if it is not right. AttachmentClocklight1.zip (207 Downloads) |
1/12/2012 8:21 PM | |
Posts: 153 Rating:
Hi,
My example in att.
More examples it is possible to look here
https://www.automation.siemens.com/logo/index_76.html?HTTPS=REDIR
Attachmentlogo 1.zip (187 Downloads) |
1/12/2012 10:18 PM | |
My programm is an example. You have to make your clock instead of Input 2 Input 1 is a press button that makes the light ON when its OFF, and OFF when its ON. Every nexttime the clock switches, your lamp goes into the clockprogramm. This new programm has a clock AttachmentClocklight2.zip (195 Downloads) |
