10/10/2013 3:29 PM | |
Posts: 1299 Rating:
Hello, you can animate the visibility of the objects with a tag. You can change this tag depending on theauthorisation levelof a user K!ke |
3/24/2014 1:38 PM | |
Joined: 12/2/2013 Last visit: 1/3/2021 Posts: 10 Rating:
Found a good solution here: http://www.plctalk.net/qanda/showthread.php?t=69673 I used a scheduled task triggered by "User change" to call GetGroupNumber on my Comfort Panel TP700. Though group number isn't the same as authorization, it does the trick for me. Note that the scheduled task "User change" isn't triggered at startup, so your tag will have its default value at startup, unless you do something about it. You can call GetGroupNumber at some other event as well. |
