7/13/2010 7:52 AM | |
Posts: 2964 Rating:
Hello.... You can also try to use Cycle 84 "Rigid tapping" and check the same....you can see the programming manual cycle in DOCON CD/WEB. http://www.automation.siemens.com/doconweb/content.asp?item=1905&cd=sinumerik_simodrive_04_2010_e&scope=all coming to the parameter what you have changed is for backlash only.. i understand noramlly for the tapping and threading this parameters are changed.
7/13/2010 3:46 PM | |
Joined: 10/28/2009 Last visit: 6/27/2024 Posts: 18 Rating:
Ekalavya,Thanks for the information. I'll do some research and see if I can't get my tapping dialed in. Have a good day!
