3/29/2011 8:38 AM | |
Joined: 1/28/2009 Last visit: 5/2/2024 Posts: 6838 Rating: (1359) |
Hi You can define variables i, j to access any cell in the matrix. By selecting proper values for i, j (for example from HMI) you can read or write the value.(indirect addressing with SCL) TEST:=MATRIX1[I,J];
Check the following link: How do you import an Excel list with STEP 7 variables into a data block? regards |
3/29/2011 5:04 PM | |
Posts: 2348 Rating: (263)
Please mention the size - 100*100 reals are ~40kB. If you have several tables this could turn into a problem. |
5/3/2011 11:29 AM | |
Posts: 6 Rating: (0) |
Ok, thank you very much for your reply. I guess I just have to live with that the code has to be edited somewhat between projects. Thanks again! |
