6/4/2013 4:12 PM | |
Posts: 49 Rating: (0) |
Pls help
i have a problem when opening my operating system Win XP as in attachment . how can i solve this problem. thanks alot Attachmentloading configurator.PDF (154 Downloads) |
6/5/2013 10:52 AM | |
Joined: 3/14/2008 Last visit: 8/7/2024 Posts: 2080 Rating: (931) |
Try to run the station configure on the ES..If not working, the displaying error that shows up can help you further.. You can also try to import the xdb file which lists the configuration of the selected station. |
6/5/2013 11:26 AM | |
how can i import the xdb file thx
6/9/2013 5:47 PM | |
Hiii surya105
thx for your helping . i try to excute your procedure but some errors appear as in attachment. pls advice me what shall i do ? ahmed abdelhady Attachmenterrors.pdf (123 Downloads) |
6/10/2013 8:32 AM | |
Posts: 140 Rating: (7) |
Hi Ahmed, Seems there is an issue in Station Configurator. Install "Simatic Net" once again and try the option. |
6/10/2013 8:26 PM | |
Hiii surya105
i install the whole programe again.but unfortunately same problem what shall i do ????!!!!!!!! Attachmentstationmanger.pdf (106 Downloads) |
6/11/2013 6:26 AM | |
Hi, Try to install in some other machine and try to downlaod. |
