8/27/2014 12:27 PM | |
Posts: 215 Rating: (6) |
Hi Frederick, I assume your configuration to work. Go to TIA Portal Help and enter "Basic Panel", scroll down to communication. I put the result attached. So one Panel should be able to handle up to 4 LOGO! 0BA7. An example for prgramming is here. It's up to you to modify the example by applying a real panel using 4 connections or simulate a panel using 4 connections or simulate 4 panels using each 1 connection. Please tell me if one of the proposals works. Regards |
