4/17/2016 1:39 PM | |
Posts: 198 Rating: (36) |
I am using microSDHC its working fine.2gb |
5/25/2017 6:07 PM | |
Joined: 12/18/2014 Last visit: 9/18/2024 Posts: 33787 Rating: (4195)
I have formatted different micro SD cards with the default settings of Windows. It worked with all. |
5/25/2017 8:11 PM | |
Posts: 6 Rating: (0) |
Hi, I have tested FAT32 with default cluster size and it failed. Nest step I tried FAT32 with 4092 cluster and then it worked well. don't know why. any clue? |
5/25/2017 8:55 PM | |
Ok thank you, What if you use 1024 bytes or 32 kbytes? Is it working what ever the cluster size? Thank you |
