7/21/2010 4:31 PM | |
Posts: 10 Rating: (0) |
Thanks for that will have to cut down on messages. I am quite new to Logo how would you connect M27 to change between characters in text block. Cheers |
7/21/2010 4:59 PM | |
Posts: 661 Rating: (123) |
1st) How to enable/use the different character sets you can find here on page 60f http://sitrain.automation.siemens.com/DE/sitrain/mcms/sitrain2/content/DE(en)/Documents/logo_in_details.pdf Siemens used two character sets also in this example: http://www.automation.siemens.com/salesmaterial-as/software/applications/logo/password_protected_outputs.zip 2nd) How to enable flag 27 depends on you. - wired input I - Cursor key C -function key F As C and F has momentary pushbutton function, use a pulse relay between C/F and M27. |
7/22/2010 10:17 AM | |
Posts: 153 Rating: (15) |
Hi_GATTL The theme "LOGO TD! Panel with Russian text" was at a forum |
7/22/2010 10:20 AM | |
Thanks for that , have been labouring under asumption M27 had to be connected on the output. Tried it in our program and works fine. |
