4/22/2008 7:50 AM | |
Posts: 22 Rating:
Help example...... Logo KNX for combine Synco RMK770 |
4/22/2008 11:03 AM | |
Joined: 9/27/2006 Last visit: 7/7/2024 Posts: 12268 Rating:
Hello Mkulmx; Maybe the following pdf files can clarify things: The following document from Sienes Building technologies describes the Konnex S-mode data points that can be exchanged with a RMK770 digital boiler controllerover a Konnex connection. http://www.buildingtechnologies.siemens.com/NR/rdonlyres/D351C170-B49F-4DCE-B91E-0675A7500926/0/siemens_016_SmodeDP_Synco_en.pdf The basic RMK770 manual also explains how it can be setup as part of a KNX bus: http://www.siemens.nl/sbt/doc/klt/N3132en.pdf Hope this helsp, Daniel Chartier |
4/22/2008 5:10 PM | |
Posts: 22 Rating:
LOGO KNX 16 Analog for 16 digital data.... synco rmz792 out LOGO KNX..... |
4/23/2008 4:03 PM | |
Posts: 22 Rating:
Attachmentlogo knx.pdf (755 Downloads) |
4/23/2008 4:05 PM | |
Posts: 22 Rating:
AttachmentLOGO!AutomatykaBudynkow.pdf (848 Downloads) |
4/24/2008 11:59 AM | |
Joined: 8/25/2005 Last visit: 7/5/2024 Posts: 1162 Rating:
Hello Mkulmx, couldn't answer your question. But maybe this info will help others to answer your question. Searching within the Product Support I found this Produkt: 6BK1700-0BA00-0AA1- LOGO! COMMUNICATION MODULE EIB
Think this is that one you are using. Note within the pdf there is a MLFB 6BK70010BA000AA1given. Think there is a typo Maybe following the link you will find a way to answer your question by your one. Best regards Sabine |
4/24/2008 4:55 PM | |
Posts: 22 Rating:
Help forum for Siemens Synco "SBT" |
