2/13/2013 7:14 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (714)
Hello, I think you can use the example given in this thread: sample and holdRegards, Marcjan |
Problem solved? |
2/19/2013 10:59 AM | |
Hello, I have changed the example i refered to a bit, hope this is what you need. Regards, Marcjan Attachmentsample_and_hold_2.zip (294 Downloads) |
2/20/2013 9:00 PM | |
Posts: 4 Rating: (0) |
thankyou for the quick response, the file is showing corrupt, would you mind uploading it again. I will try it straight away Thanks again
2/21/2013 8:36 AM | |
Hello, File is o.k. here on multiple PC. It's made with Logosoft 7.0.30, do you have that version? If not upgrade your software: Demo software , upgrades/updates, driversRegards, Marcjan AttachmentLOGO!Soft Comfort - sample_and_hold_2.pdf (281 Downloads) |
2/24/2013 2:14 PM | |
That worked perfectly and such a simple solution-Great work |
