4/11/2016 11:19 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating: (122) |
New question published by secs is split to a separate thread with the subject LOGO SOFT COMFORT freeze. Best regards |
4/15/2016 11:06 AM | |
Posts: 198 Rating: (36) |
possible reasons (1)check network cord(2) un proper IP configuration both sides pc and logo. solutions if your logo is brand new then use default ip address sub mask and gateway in pc connection configuration. you can use some ip detection software if you plc device pre ip addres cofig. or logosoftcofort v8 auto ip detection function use that function.for logo oba8 AttachmentEN_Connection_LOGO!8-PC.pdf (921 Downloads) |
4/16/2016 6:20 PM | |
this will help connection problem for logo oba7
AttachmentEN_Connection_LOGO!0BA7-PC.pdf (700 Downloads) |
6/27/2017 2:01 PM | |
New question published by HHHHHHHHHHHH is split to a separate thread with the subject Problem with connecting logo! with pc. Best regards |
11/6/2017 8:00 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating: (172) |
New question published by moreno_tech is split to a separate thread with the subject Aren't able to communicate the PC with LOGO. Best regards |
