6/2/2014 3:34 PM | |
Posts: 3 Rating:
And here's the install log. It has my original install in 2011 and my v7 attempt at the bottom. |
6/2/2014 6:19 PM | |
Posts: 378 Rating:
Hello, The problem is serial driver librxtxSerial.jnilib file is not matching your mac os archtecture and version. I have attached here librxtxSerial.jnilib file compatible to mac os 10.6 1. Locate the file on your installation folder (as per your log file located: /Users/dreens/Applications/LOGOComfort_V7/bin/librxtxSerial.jnilib) 2. Extract the file attached here and replace. I hope this works! AttachmentlibrxtxSerial.zip (255 Downloads) |
6/2/2014 6:36 PM | |
Posts: 3 Rating:
Wow worked like a charm! I didn't even need to reboot the program after replacing the file. Thanks so much for your quick and professional work. David |
6/5/2014 7:20 PM | |
Posts: 1 Rating:
Hello I have the same problem, but i use Mac OS 10.9. Does the same driver you recommand work for this version? Regards
